This section describes the procedure for configuring VMANs. Before
        configuring VMANs, review Guidelines for Configuring VMANs. To configure a VMAN, complete the
        following procedure at each switch that needs to support the VMAN:
        If you are configuring a SummitStack, or
          an ExtremeSwitching series switch, enable jumbo frames on the switch.
You must enable jumbo
            frames before configuring VMANs on these systems.
        Create a VMAN using the command:
create vman
              vman_name  | vman_list vr vr_name
        Assign a tag value to the VMAN using the command:.
configure
            vman vman_name | vman_list
            tag
            tag_id
        To configure PNP ports on a PEB or PB, use the following
          command with the tagged option:
configure
            vman vman_name | vman_id
            add
            ports [ all | port_list ] {untagged
             | tagged}
        To configure CNP ports on a PEB, use the following command
          with the untagged option:
configure
            vman vman_name
            add
             | tagged}
You must configure CNP ports as
untagged, so that the
            S-tag is stripped from the frame on egress. If the
port-cvid is
            configured, any untagged packet received on the port will be double tagged with the
            configured port CVID and the SVID associated with the VMAN. Packets received with a
            single CVID on the same port will still have the SVID added as usual. As double tagged
            packets are received from tagged VMAN ports and forwarded to untagged VMAN ports,the
            SVID associated with the VMAN is stripped. Additionally, the CVID associated with the
            configured port CVID is also stripped in the same operation.
        To configure CEP ports on a PEB, do the following:
            Use the following command to establish a
physical port as a CEP and configure CVID mapping and translation:
configure vman vman_name | vman_id
                add
                ports
                port_list
                cep [ cvid <cvid or
                  cvid_range> { translate
                <cvid or cvid_range> } } | port-cvid <port_cvid> ] }
            Use the following commands to add or delete CVIDs
for a CEP and manage CVID mapping and translation:
                ports
                port_list
                add
                cvid {cvid | cvid_range} {translate
                cvid | cvid_range }
                ports
                port_list
                delete
                cvid  {cvid |
                  cvid_range }
            Use the following commands to manage CVID egress filtering
for a CEP:
enable
              vman cep egress filtering ports {port_list |
              all}
            disable
              all}
        Configure additional VMAN options as described in Configuring VMAN Options.
        To configure a VLAN to use a
          VMAN, configure the VLAN on the switch port at the other end of the line leading to the
          VMAN access port.
